跳转到主内容
加入维修社区 - 创建账户
MacBook Pro Keyboard Backlight Not working
So, I got this MacBook from a friend, as he didn’t have a use for it anymore, it was originally a 2010 model but it got a logic board replacement, idk if that affects it. there were some problems with the RAM at first but its fixed now.
Anyway, I often do use the MacBook in low light and I normally can see the keyboard. So I use the backlight but to my surprise the thing doesn't work! It shows up as working on the OS (10.12.6) but nothing happens, I have tried it on other os's to see if it was a os problem but no luck.
I have checked the board for water damage, none.
Checked the connector in the board and the actual cable, both fine.
there haven't been any other problems with the MacBook otherwise I am just asking if it is a problem with the logic board or if its the backlight itself
Hope to hear from someone who can help
cheers ;)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Have you made sure you check the proper cable?
Review this guide Step 14 MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Is the cable damaged? I’ve seen a few torn or the latch missing.
这个答案有帮助吗?
得分 0
2条评论:
No, its not damaged I've gone and done extensive analysis on the %#*@ thing but I haven't found anything clearly wrong with it.
完成的
@Aaron Official - Did you check to see if the connector has voltage? If it doesn't then that gets into the driver logic (could be a fuse as well)
完成的
添加一条评论
添加你的答案
Aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 209
