跳转到主内容
Usage of a SSD as an external drive
Hi guys,
My MacBook Air is not starting. the battery charges (the MagSafe turns green), but the MacBook doesn’t start… I really don’t know what’s happening. The Apple authorized dealer (repair) told me that is vintage.
Ok, but I would love to recover files or try to solve the problem. It’s a used MacBook Air but it is very well cared. It is a crime to put it in the garbage!
Can I use the SSD (flash storage with PCIe) installed on this MacBook as an external drive? Is it possible to use it as an external drive or try to use it in another MacBook? What should I do?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Here's more details on your Apple SSD The Ultimate Guide to Apple’s Proprietary SSDs
完成的
添加一条评论
2个答案
已选择的解决方案
there is adapters you should be able to find to at least use it to dump the data.
这个答案有帮助吗?
得分 1
1条评论:
Thanks! I´ll manage this...
完成的
添加一条评论
Here’s the case you’ll need OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much! I´ll manage to buy it!
完成的
添加一条评论
添加你的答案
MARCUS VITOR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 4
总计 126
