My Nextbook table will not turn on?
My nextbook will only turn on momentarily when I plug in the charger. Why will it not turn with power switch? Is the batery bad? How do you tell?
If the battery is removable, try taking it out for about 10 minutes and put it back in. If that doesn't work, try a different charging cable.
If both fixes don't work, then the battery may need replacing.
这个答案有帮助吗?
I disconnected the battery for about 5 min. with results. I will try a new chord when i get one.
Thanks.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
