跳转到主内容
Keeps showing a circle with a diagonal though it
Trying to boot to a mac os yosemite usb stick, every time it fails, :/
Also whats the highest macOS it can run,
ALSO thanks in advance :]
When trying to make installer the 2nd time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Sounds like you may have not prep’ed the thumb drive correctly.
First you need to format it using a Mac with a GUID Journaled file system. Next you need the correct OS installer copied to it.
The highest your system can handle is macOS High Sierra (10.13.x) but I strongly recommend sticking with Sierra (10.12.x) as High Sierra alters the file system from HFS+ to APFS which does not run too well on older SATA based drives. Get the installer from here: How to get old versions of macOS older installers have an expired certificate.
Follow this guide to setup the installer onto the thumb drive How to create a bootable macOS Sierra installer drive
Last step if the drive won’t boot up on its own with the thumb drive, time to restart your system and press the Option (⌥) to get to the startup manager so you can select the thumb drive.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 2
9条评论:
I feel so stupid right now, XD
Thanks @danj
完成的
@beanman56 - Let us know how it goes!
完成的
@danj I can't make the installer,
on my two other macs it didn't work
完成的
@beanman56 - Well you need to explain why it didn't work
完成的
On macdaddy.io's application,
It ALWAYS make bootable mac os usb sticks
But with sierra it keeps saying
"An error occurred.
Try ejecting the destination disk and reinserting it, or rebooting. It probably couldn't be unmounted to erase it."
BUT in disk utility it can unmount with no problem
完成的
显示更多的4条评论
添加一条评论
A prohibitory symbol, which looks like a circle with a line or slash through it, means that your startup disk contains a Mac operating system, but it's not a version or build of macOS that your Mac can use.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 233
