Circulation pump starts running when I switch the machine on
When I switch the machine on the circulation pump starts running and doesn’t stop when I open the door
Circulation or drain pump?
If it is the drain p/p there is possibility to be because of aquastop switch, witch is mounted at the bottom of the machine.
这个答案有帮助吗?
Definitely the circulation pump, checked the floats and drain pump, not the problem
I’ve reset the machine, pressed start, the drain pump comes on, then stops, starts to let water in for a few seconds then the circulation pumps starts, only stops when I press the stop button
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 742
