跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
Why is my replaced battery only charging once it has been drained?
I replaced my battery a second time after the first stopped charging at all. The second battery only seems to charge once it has run out completely and not while plugged in and being used - I have attached a coconutBattery screenshot. Any ideas?
I have updated to Monterey to see if it helps. Here is the current info:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you. I guess there’s not much I can do about that. ☹️
完成的
添加一条评论
1个答案
已选择的解决方案
You have a threshold issue within the charging control logic. Sadly that’s part of the logic board that needs service.
You might want to try the other side ports a try to see if thats better as your system has two Intel JHL6540 Thunderbolt 3 controllers (light Blue marked chips)
Otherwise its within the SMC logic which you could have hit while disconnecting the battery (light Green marked chip)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 47
