How to fix broken ram slot
One of the two ram slots broke, is there a way to fix it
There is. but your not going to like it. but contact Louis Rossmann of Louis Rossmann group in NY New York. he may be able to repair it. https://www.rossmanngroup.com/
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 189
6条评论
@danj do you have any idea?
由 Ben Capehart 完成的
What broke? Post some pics so we can see 在已经存在的问题里加入图片
Most of the time there is little you can do as the frame is well anchored. You would need to replace the frame which is not easy and the cost would be more than replacing the logic board. If the latches are damaged you can try wedging some plastic to hold the needed pressure on the SO-DIMM.
由 Dan 完成的
@danj its not the frame or latches,
Its the slot, a picture wouldn't be very useful,
The problem is inside the slot
由 Ben Capehart 完成的
@beanman56 - New frame then, I would just replace the logic board at this point MacBook Pro 13" Unibody (Mid 2010) 2.4 GHz Logic Board
由 Dan 完成的
:| don't want it THAT much,
But thanks again @danj
由 Ben Capehart 完成的
显示更多的1条评论
