Where can I get some airport and speaker screws?
I fixit doesn’t have any,
I NEED THEM TO FIX MY MAC
you need a friend that has a thread gauges and a caliper measuring device. he will tell you it is a M(#) or what the tread and shaft size is. most local hardware stores can get them. If you can’t find locally McMaster will surely have them.
这个答案有帮助吗?
i dont have the screws though
@beanman56 I am guessing the speaker ones are M2x3.8 and M2x5. the translating for the first one is M2x4mm
@beanman56 actually this set is better for you needs. except it has limited M2 ones. the other kit has more M2 types.
its on the left side,
also does the does the set it include:
Two 8 mm Phillips screws
One 4mm Phillips screw?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 20
