跳转到主内容
Repair guides and support for your Toshiba TV.
194 个问题 查看全部
2019 32in Toshiba power connected won’t turn on
I have a Toshiba 32 inch HD ready TV, the red light is on when I switch it on it turns green but then goes red again. The screen remains black at all time. Is this a common and easy problem to fix or should I just replace it ? It’s in a spare rarely used room.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
My answer depends on if you feel adventurous or not. If so take off the back cover and inspect the power supply board(without touching it) Look for the bigger round chimney like things witht he X on them. That X should be flat or slightly indented. if you find one or more were it is not than you can either buy a new board or read the numbers on each faulty one and order them and swap them with a soldering pen.
the board is the easiest but the soldering is the most fun and the cheapest
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hawdy98 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 36
