跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
My internal ssd is not displayed in disk utility
I deleted "other volumes" with "view all" options, and now my internal ssd is not displayed
Hi! I recently wanted to format my old MacBook air, and reinstall OS sierra. During recovery mode, in disk utility, I saw that after formatting Macintosh HD, there were like 40gb in use, by "other volumes". I thought that they were other users profile (I had 3 users active in the macbook) so I wanted to delete those as well. Using "view all" options, I just formatted the other volumes container. The thing is that after this, internal ssd is no longer displayed in disk utility. The "view all" option is no longer available. "Diskutil list" command in terminal doesn't show the ssd neither. I did a SMC and NVRAM reset and nothing changed. The ssd is ok, is not a hardware wise problem. Any thoughts? I'll leave a pic of the only thing i see when I open disk utility
Partition tab:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
7条评论
Click on the disk0 What do you see then? Post a snapshot so we can see.
完成的
@danj I added 3 extra images, clicking the items on the list, also added what diskutil list brings up when I run it on a terminal console
完成的
@nemesys660 - Click on the Partition Tab as you won't see anything under First-Aid section.
完成的
@danj I added the partition tab
完成的
@nemesys660 - OK so you have a partition just nothing on it! Time to run the OS installer.
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
For some reason your disk boot records are messed up. Lets create a bootable OS installer. Get a 32GB thumb drive which you’ll need to format with with GUID and a journaled file system. Down load from here How to get old versions of macOS follow this guide to set it up How to create a bootable macOS Sierra installer drive.
Once built from your other system reboot your MacBook Air using it and this time delete and reformat your internal drive so its fully clean. Now running the installer you should be able to install the OS onto your internal drive. It will automatically setup the partition and install the OS just follow the prompts.
这个答案有帮助吗?
得分 2
3条评论:
Hello, same problem here. I tried to install on an external ssd and it was ok, but even in the mac os diskutility or teminal it doesnt show the internal ssd
完成的
Please where you able to resolve this issue???
完成的
@nosakharee76644 - This is a very old question! How about creating your own with all of your details
完成的
添加一条评论
添加你的答案
Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 68
总计 2,145
