跳转到主内容
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
What does blinking LEDs 1 and 2 mean?
iMac 21.5” does not power up, no chime is heard. I know that LED codes are: LED 1 on= trickle voltage from power supply is detected by logicboard. LED2 on= logic board has detected proper power from the power supply when the computer is turned on.
The problem is BOTH LEDs 1 and 2 are BLINKING (not ON continuously) when I connect the AC power cable to the mains wall socket. What problem does this point to?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论:
Can you offer some additional details on what preceded things here.
完成的
Nothing unusual happened prior to. Thing just suddenly won't turn on.
完成的
Where is the light coming from?
完成的
Light comes from the vertically arranged LED array on the logicboard.
完成的
添加一条评论
1个答案
What does the other LED’s telling you?
Did you try reseating the RAM? Did you replace the RAM you might have a bad SO-DIMM.
这个答案有帮助吗?
得分 0
3条评论:
The RAM is permanently soldered to the logicboard in this model, and cannot be replaced.
完成的
Dan, when I press the power button, the 2 other LEDs remain unlit, #1 and #2 LEDs turn off. When I release the power button, LEDs #3 and 4 remain off and #1 and #2 start to blink again.
完成的
@Bernie - Sorry your right! One of the few iMacs with soldered RAM.
I think your logic board is blown then.
完成的
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 258
