跳转到主内容
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
45 个问题 查看全部
Why is my oculus going black every 30 seconds?!
While wearing my oculus, it goes black every 30 seconds or so, and I have to physically take it off my head and put it back on for it to come back on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I'm gonna add to this post for any passers by, since this is an older thread.
This is a software bug I've experienced before.
Just like graphics drivers on High-end computers not liking to be stacked with updates, the early software versions for the Oculus Quest also doesn't like it, and it tends to get internal parts of the software corrupted.
To resolve this, You'll likely want to connect your headset to a computer, and get any files you need off of the headset. Search on Google where certain games have Save Data stored on the headset so you can back them up to your computer to restore later. Once you're done doing this part, you're ready to Reset.
  • Power off the headset.
  • Once the headset has shut down, hold the Power button and the Volume Down button ("-") at the same time.
The headset will power back on and you will see a screen that looks like this shortly after in the headset.
Use the Volume Buttons to navigate up and down the menu, and the Power button to interact with the Selected menu item.
  • Select "Factory Reset" in the menu and confirm the Reset by selecting "Yes, erase and factory reset"
After doing this the headset should begin to erase it's internal storage and will boot up into first time setup once it's done.
Let the headset update if needed during setup with a mobile device or standalone.
这个答案有帮助吗?
得分 2
添加一条评论
Is it Plugged into a PC?
If so, you have to many things plugged in to your pc for it,
Windows has trouble with that
这个答案有帮助吗?
得分 1
2条评论:
It is not plugged into anything.
完成的
maybe its the graphics card or the intergrated graphics if it has it
完成的
添加一条评论
添加你的答案
crystalann500 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 140
