跳转到主内容
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Replacing a fault GPU with a new GPU
I have a MacBook Air mid-2012 A1466 model and I was wondering if there a way that you can take the bad GPU and put in a other one like it and just resoldier the new one to replace the bad GPU wondering if that is possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Replacing large BGA chips requires proper tools for the task otherwise you’ll either damage the logic board or the chip. Then you have the issue on what will work and available which is very difficult to get as a new part.
Frankly, replacing the logic board is just easier! And given the risk of damage as well as access to the needed gear a lot cheaper! MacBook Air 13" Mid 2012 Logic Board Replacement
这个答案有帮助吗?
得分 0
6条评论:
If I need the proper tools where would I find them?
完成的
@Jordan Chapman - The guide I posted (Blue URL link) will give you a shopping list of what's needed.
Frankly I find the iFixit tool kits a better purchase for most folks as it gives you a good collection of whats needed beyond this one job of replacing the logic board Pro Tech Toolkit
完成的
Whats the tools I need to replace the GPU from the logic board.
完成的
@Jordan Chapman - A temperature controlled reflow station they go for about 4k, not cheap for a one time use its a bit much.
I've been fixing systems for a good 40 years, even I don't have one as its not worth it for the few times I would use it. Besides replacing the logic board is just cheaper for the customer and easier for me!
The only option is finding someone who makes a living just replacing large BGA chips like CPU's & GPU's on laptop logic boards.
完成的
Another question is there a way you could turn off the BGA chip or CPU/GPU chip like you can do in MacBook Pro 2011 or later but on a MacBook Air mid-2012?
Just wondering out of curiosity? Bc I know that they are two different machines but I just wanted to know if it is possible.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Jordan Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 488
