跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
150 个问题 查看全部
How can I my battery health back to 100%?
Hello everyone
I own an iphone 11 pro and I want to change its battery, and at every gsm service I go to they tell myself that they can change my battery (aftermarket) but I can't update my battery health to 100%.
Is there a software program or device that I can purchase to do this?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Unfortunately you will need to de-solder the original phones battery flex cable as it has a chip on it that is married to the CPU. You will then need to solder or spot-weld it to the new battery. You will also need a battery extension flex as well as battery data programmer.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Agnes,
Outside of going to an Apple service provider, the easiest way I've found to do this is to get a screen/battery reprogrammer from Qian Li or JC, remove the original battery, (Make sure to follow the proper guides) connect it to the programmer, press read, then connect the new battery to the programmer and press write. Once you reassemble the phone, the battery health should be reset. Now, this isn't a foolproof solution, as Apple is trying to prevent you from doing this. Sometimes it doesn't work at all, sometimes it doesn't reset it and gives you the old percentage. This is just the best solution I know of.
Hope this helps!
-Cam
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
agnes emilia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 1,052
