跳转到主内容
加入维修社区 - 创建账户
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
I want to upgrade RAM
I have an iMac Pro 2017 8 core 3,2 with 32 gig RAM (EMC 3144). Can I upgrade the RAM on this model?
there is no reference to EMC 3144 on the ifixit site
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
We don’t have a guide to upgrade the RAM for this system. Apple made the design much harder than the regular 27” iMac’s which have a RAM access door. Here the system needs a complete teardown lifting the logic board fully out to gain access to the four SO-DIMM slots.
Unless you’ve done a bit of work on the newer 2013 ‘Thin Series’ onwards iMac’s so you are comfortable in taking the display off and have taken out the logic boards I would recommend you find someone who has, as this is an expensive system to get repaired if you make any errors.
OK I’m going for it!
First you need special PC4-21300 32 GB ECC Registered RAM iMac Pro Memory Maxxer RAM Upgrade Kit
Follow this guide to take the display off iMac 英特尔 27 英寸 Retina 5K 显示屏更换 the cable connections are slightly different than what this guide shows. Here’s a better image of the connections.
Review this iMac Pro拆解 for guidance as the steps of removing the logic board as that’s all there is. Step 7 is as far as you need to get to.
Install 128 GB of RAM in your EMC 3144 iMac Pro. Compatible with 3.2, 3.0, 2.5, or 2.3 GHz Late 2017 iMac Pros.图片
产品
$799.99
iMac Intel 27" Retina 5K Display 显示屏图片
指南
难度:
中等
30 - 45 minutes
iMac Pro图片
指南
iMac Pro拆解
难度:
中等
这个答案有帮助吗?
得分 4
1条评论:
Yes to all of this. And yes to this is not a repair for folks who are inexperienced. It takes A LOT of doing, since the whole logic board needs to be removed, the DIMM slots are on the back of the board. But it's definitely plausible.
This is a procedure Apple will also do for you, but I would totally understand not wanting to take it to them since RAM will absolutely be pricey. And if it is a repair you can do yourself then why bother.
完成的
添加一条评论
添加你的答案
Andrew Wessels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 40
总计 1,631
