跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Draining the battery on an ipad mini A1432
So i’m doing this iPad mini screen repair. I’ve used the CPB Heating mat to lose the adhesive tape so i can pry it open. The heating mat works wonders, it opens with less mess. I always test after opening the damaged screen to see if the iPad still works. The device works but since that screen is cracked really really bad, the touch screen doesn’t work at all. My question is, how long that the battery will last since I want that thing completely dies so i can safely disconnect and reconnect the ribbon cables. Please assist, thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I was able to do the work without any further issues, kudos for your assistance!
完成的
添加一条评论
1个答案
已选择的解决方案
It would be quicker and safer to disconnect the battery. You will have to remove the plate anyway to disconnect the screen flex, and the battery connector is right beside it.
这个答案有帮助吗?
得分 1
2条评论:
Oh okay, I can still disconnect the battery regardless if the iPad is still on.
完成的
@uitadmin Yes it is perfectly safe to do so.
完成的
添加一条评论
添加你的答案
Gabriel Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 290
