跳转到主内容
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
75 个问题 查看全部
Vertical Barlines on LCD
My phone is dropped and it has a crack inside.it has no display but vibration is istill OK if I press Power on. Probably, screen issue only. So I ordered a replacement LCD display. Before fixing it to the phone, I connect if first just to try if it is working. And it worked. Though, it seems not as good as the original one(finer). So, I proceed the replacement and when I was about to try it after assembly, vertical bars appeared.
There is no picture, only vertical bars(gray, black, green etc) are interchanging.
What might be the reason?
Is it still repairable? please help me for options. I have to recover the data on my phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check your cables make sure they are connected correctly. If the are connected correctly then the LCD may have been damaged during installation.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
earvin Latorre 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 15
总计 53
