跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
203 个问题 查看全部
How to fix 15" MacBook Pro Retina 2018 spacebar key?
Hello everyone, I have one of those less-than-ideal 15” Macbook Pro Retina 2018 (Touch Bar). Unfortunately, my spacebar key got stuck a few days ago, after investigating and trying to remove the spacebar key, I accidentally broke the hinge clips that are secured to the transparent baskets, rendering the key useless, I did order a particular kit from Replacement Laptop Keys, that comes with the key, the hinge and the button cup (small transparent piece in the middle on the hinge).
It seems like the only way to fix this would be to remove the cup and then put it back in place after securing the hinge clips to the transparent side baskets first, then securing the middle piece after. It seems like it’s stuck with glue, I was just wondering if I could apply adhesive remover to loosen that part? I could use something like a very small amount of glue to put it back in place perhaps.
My situation is that it will not be covered under Apple warranty because I changed my own battery recently, making me an unauthorized third party repair. And because of that I will not be eligible to get the keyboard replaced. As the machine is almost 3 years old, I certainly do not wish to pay 600$ to fix that (they won’t fix it even if I pay them apparently). It’s one of those machines that is just bricked from official Apple repairs I’m afraid.
I want to thank everyone in advance if there are any solutions available that don’t deal with Apple directly. Cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Good news! You are covered under the extended warranty program! Replacing of your battery doesn’t alter things!
Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
Find your way to an Apple Store or authorized service center.
这个答案有帮助吗?
得分 2
8条评论:
Can I just get confirmation on that? I was told that they could see if a battery was changed by a 3rd party, is that correct or are they bluffing and couldn't actually tell if the battery was changed. Is there somewhere on the motherboard that registers these interactions? Thanks !
完成的
@sakura_bonsai - Confirmed! They are legally responsible to fix the keyboard. You don't see any exceptions in the TN do you? Nope!
I have heard of AASP's complain as they don't get paid enough for the job. So I would recommend just going to the Apple Store as my first option.
完成的
@danj Okay great ! That is reassuring me a whole lot, what if the plastic membrane is destroyed or removed under the key, would that be an issue to them or do they have to need to change the whole keyboard anyway? I'll just pretend one of the key corners was stuck and upon pressing at another corner the hinge just snapped, rendering the key unfunctional.
完成的
@sakura_bonsai - Don't volunteer anything.
完成的
So after reaching to the Apple store, they agreed to replace the keyboard under their keyboard service, until they opened the laptop to find the replaced battery, and then denied the repair as it was flagged for unauthorised modification, is there any other way I could get that repaired? Apparently it is now unservicable according to their policy, man do I hate this company sometimes. I instantly regret trying to change the battery myself at this point...
完成的
显示更多的3条评论
添加一条评论
you are left with nothing but an unauthorized replacement of the spacebar key or whole keyboard possibly. I had to do the same 3 years ago... Apple never leaves a chance to deny you free service. Make sure you go to a good repair shop, get your spacebar key replaced, and test it with a space bar clicker to be double sure... If that does not work, go for the full keyboard replacement.
这个答案有帮助吗?
得分 0
1条评论:
@irwinnick - The Butterfly keyboard repair program has a time window! "for 4 years after the first retail sale of the unit." A 2015 ~ 2017 are now no longer covered! 2018 is on the edge! Depending on the sale date.
Even still I would try hard to get it covered as a warranty exception but you need to keep your composure and weep profusely, rivers help!
完成的
添加一条评论
添加你的答案
Philip Roy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 46
总计 2,505
