跳转到主内容
General repair information on LG washing machines.
How do I unlock CL on LG
How do I unlock CL on LG Inverter Direct Drive True Balance Model Number WM3900HWA ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
10条评论
My LGWasher say CL lock
完成的
@Ilene Barton
What is the model number of the washer?
完成的
non of the above worked
完成的
@michael1950
完成的
How do I turn off cl code model # WT1101CW
完成的
显示更多的5条评论
添加一条评论
10个答案
已选择的解决方案
Hi @crbc
Turn on the power to the machine and then press and hold the Rinse + Spin buttons (both together) for 3 seconds to either activate or deactivate the Control Lock feature.
这个答案有帮助吗?
得分 5
20条评论:
This is a true balance top loader how to turn off child lock
完成的
@Arlene Jackson
完成的
This didn't work for me... have a 14kg top loader.... thanks for the suggestion though.
完成的
@relax
完成的
On my top loading super inverter LG washer I just had to press the child lock button for three seconds. I didn't notice but it actually says "Child lock" in very small letters.
完成的
显示更多的15条评论
添加一条评论
Hi @Barb Wandsnider
Press and hold the soil level button for 3 seconds during the wash cycle to disable the child lock.
Here's the section from the user manual that explains how to enable and disable the feature.
这个答案有帮助吗?
得分 3
10条评论:
I held down the rinse & spin button for 3 seconds. It released the control lock.
完成的
My question: why does the manual not describe how to deal with this error code nor even list it in the error message section??? Thank goodness for Google. Press and hold the water plus/child lock button worked for me.
P.S. I bought this machine 8 years ago. NO other service issues 😌
完成的
@maryalicee66424
The CL code is NOT an error code.
It is usually described in the user manual under the features i.e. Control Lock or Child Lock and is there to inform whether the lock has been enabled or disabled, usually done by the user of the machine
完成的
My panel shows child lock and CL. I tried pressing rinse and spin for more then 3 seconds it does not work. Please advise.
完成的
@florence65414
Not every washer uses the same button sequence to enable/disable the Child lock feature.
完成的
显示更多的5条评论
添加一条评论
Press and hold the CHILD LOCK button for 3 seconds
这个答案有帮助吗?
得分 1
1条评论:
Thanks! Worked on model number WM4370HWA
完成的
添加一条评论
None of the above worked, probably because my panel is different. Then I noticed on my LG the Half Load and Energy Saver had an note below them: Control Lock.
I pressed both simultaneously and the frustrating CL was cleared.
这个答案有帮助吗?
得分 1
添加一条评论
This worked on my LG model, which has a similar control panel to yours:
For front-loading washer dryer combo “Inverter Direct Drive True Balance” LG model #WM3499H*A:
1) Once LG machine is powered ON:
2) Go to the right touch-screen panel, press and hold “Pre-wash + Delay wash” buttons simultaneously for 3-5 seconds. This will turn OFF the CL (control lock/child lock). You’ll hear a little jingle when the function is processed.
3) Similarly, pressing this combo simultaneously again for 3-5seconds will turn back ON the CL .
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
I pressed both rinse and spin button simultaneously. But it doesn’t work. What if the rinse button is spoilt?
这个答案有帮助吗?
得分 0
1条评论:
Hi @shuxiantan,
What is the model number of your washer?
Not all LG models use the same lock/unlock control buttons.
If your machine does require the spin + rinse buttons to be operated, then if the rinse button is faulty it will have to be replaced or somehow bypassed to disable the CL code
完成的
添加一条评论
Help not working top load lg inverter direct drive
这个答案有帮助吗?
得分 0
1条评论:
Hi @annahernan51976,
Is it showing a CL message or light?
完成的
添加一条评论
Hi @lakjayaran59503
Not all LG washers use the same set of buttons for the CL function.
To activate/deactivate the Child Lock (CL) feature in your model, press and hold the Beeper button and the Rinse button (both together) for 3 seconds.
这个答案有帮助吗?
得分 0
添加一条评论
Hi @gailm86723
To activate/deactivate the Control Lock (CL) feature in your LG WT8400CW model washer, turn on the power to the washer and then press and hold the Deep Fill button for 3 seconds.
这个答案有帮助吗?
得分 0
3条评论:
How to deactivate a child lock on washer MEZ64580704
完成的
@mapalla
Please confirm the model number of the washer as the number you posted gives no results?
完成的
WM8900HBA Is my model number. I tried the combo pre wash and delay wash. It did not work
完成的
添加一条评论
Hi @mgurganus1
To activate or deactivate the CL (control lock) feature in an LG WM8900HBA washer, turn on the power and then press and hold the Steam button for 3 seconds.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Cargen 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 95
过去 30 天: 528
总计 58,904
