跳转到主内容
加入维修社区 - 创建账户
Refrigerators produced by Samsung. Model RF220NCTASR/AA 02 POWER SHUT OFF REFER NO LONGER COOLING
Freezer not fully freezing...
I have Samsung RF260BEAESR/AA-05 fridge/freezer. the led display shows -2 (for freezer) and 37 (for fridge) degrees….but freezer isn’t that cold to keep everything frozen (ice tray not fully frozen, ice cream are soft, etc). this whole issue happened after we had the power outage few weeks ago…and i have reset it few times, same results….even i had replaced the evap motor fan in freezer…same result. There is no error code at all since we got it. So what should i do next?? (I had thought of replacing the temperature sensor(?) that is located in the ceiling of the freezer, but it is not serviceable by any standard, but I had seen somewhere where you could buy other sensor and cut/splice the old one out and put new one in, etc…or is it the circuit board, eh??) The fridge is almost 2 years old…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Here’s the service manual for the refrigerator.
Go to p.47 to view how to get into the diagnostic test mode so that all the functions can be checked.
There are also troubleshooting flowcharts that will help as well, depending on the error code that may be displayed by the diagnostic tests.
It also has the specifications for the temp sensor (see p.58), so that you can check if it has the correct resistance at the specified temp and where this can be checked (see p.64 for freezer sensor).
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for getting back to me with the service manual...as I did the self diagnosis as noted in the manual twice, and there is no error pops up on the display....
完成的
@rickkrakora
Place an appropriate thermometer in the freezer and check what temp it shows.
Did you check the resistance of the freezer sensor as shown in the manual to see if it corresponds to the display reading?
完成的
添加一条评论
添加你的答案
rickkrakora 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,105
