跳转到主内容
A laptop by Lenovo that can function as a tablet.
45 个问题 查看全部
My fans make noise when they spin up.
I have a Lenovo Yoga 720-13ikb, I’ve been using it for 3-4 years now. My laptop fans have started to make some noise when they spin up, it is a continuous noise. What will I have to do to manage this issue, do I replace the fans(I’m not sure if they are a part of the heat sink assembly or a separate module) or would cleaning them out solve the issue(if so how do I clean the fans).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @vck911
Here’s the hardware maintenance manual for the laptop.
Go to p.44 to view the necessary pre-requisite steps and then the procedure to remove the “thermal unit”. The fans and heat sink are one complete module.
If they’re dusty, gently brush the fan blades with a soft brush and then vacuum them.
If the fans are faulty and need replacing, the part number is 5H40N67860 (supplier example only). Search online using the part number only to find suppliers that suit you.
这个答案有帮助吗?
得分 1
1条评论:
Hi @jayeff, thank you for your response. I will clean the fans and see if that solves the problem and post an update after.
完成的
添加一条评论
添加你的答案
Varun Kulkarni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 148
