跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
295 个问题 查看全部
What should I use instead of an iOpener to remove the battery?
I’m attempting to do a display replacement and battery replacement on an iPad Air, and have just gotten to the step where I need to use an iOpener to remove the logic board and battery.
I don’t have an iOpener. I was only able to get this far into the repair without one because the display was already falling off from poor adhesive the last time a repair was performed on the device.
Instead of an iOpener, could I use a hairdryer or something?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, you could use a hairdryer. I sometimes use my mom’s neck heat thing and that works perfectly after putting it in the microwave for 3 minutes. What I would not recommend doing is putting it in front of a space heater as this could damage the device. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mjesticfalco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 67
