跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
204 个问题 查看全部
One Fan Spinning Full Speed After Battery Replacement
I just replaced the battery in the machine, verified all the connects a couple of times. One fan spins at full speed 100% of the time and I can’t figure out why. I tried all the standard resets too…any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hmmm. Only one fan? Which fan, just out of curiosity? I would try 2 things. See if it spits out an error when you run diagnostics (press and hold D when you power on from off). I might also download something like TG Pro, there's a 14 day free trial, and see if you're getting any weird readings from sensors.
完成的
@flannelist - Good diagnostics step!
完成的
Did you try reseting the SMC and or NVRAM?
完成的
So, here is where I'm at. I did all the resets, like SMC and NVRAM. I downloaded TG Pro like @flannelist mentioned. That all came back clean, no issues. The left fan though is running at 7000 RPM and the right fan is at 2000 RPM.
I started the machine up in a diagnostic mode and there it did say that something was up with the left fan. So not sure if this is an issue with the fan itself or the connection to the MLB/
完成的
i would try the fan MacBook Pro 15" Retina (Late 2016-2019) Left Fan
if not then this MacBook Pro 15" Retina (Mid 2018) 2.9 GHz Logic Board, Radeon Pro 560X, with Paired Touch ID Sensor OR MacBook Pro 15" Retina (Mid 2018) 2.6 GHz Logic Board, Radeon Pro 560X, with Paired Touch ID Sensor. OR MacBook Pro 15" Retina (Mid 2018) 2.2 GHz Logic Board, Radeon Pro 555X, with Paired Touch ID Sensor
Or its the ram that could cause that to happen
can you send a video of it starting up and the sound or a link to youtube or something
The problem with my 2009 macbook was the fan it wasn't going fast enough.
完成的
添加一条评论
2个答案
最有帮助的答案
Likely the tach within the fan unit has encountered an issue. This could be the fan unit or the wiring to the logic board. Basically, the resistive load of the circuit is not correct.
I would start off replacing the fan unit as well as inspect the fan connection point on the upper case (under the logic board) and then following the connection to the logic board connection.
这个答案有帮助吗?
得分 2
5条评论:
Most likely that
Also @danj can i be part of your business
完成的
@beanman56 I'm retired! Check out my bio here danj
完成的
Still can i be on your business, i can help
PLEASE let me on the team
完成的
@danj I need. help with my TOZO-T10 guide if you can help
[无效指南链接]
完成的
@beanman56 - I've changed my focus from repair to my second love photography, and a very narrow aspect which is a solo kind of thing.
完成的
添加一条评论
@gadietrich Try getting a new fan and checking the fan connector.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Greg Dietrich 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 19
总计 336
