跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
Does a SSD replacement kit fix SMART issues?
I get SMART notices when trying to upgrade a late 2014 Mac mini as above to Monterey. That is, it won’t upgrade, because the installer reports SMART problems. (Backup, replace the drive etc.)
If I replace the SSD things, will that fix the SMART issues?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, replacing the Hard Drive/Solid State drive with a new one should fix any SMART-related errors you are having.
这个答案有帮助吗?
得分 4
3条评论:
Thank you for your reply. I assumed it was so, but wanted to make certain before embarking on such a venture.
完成的
Hello again - thanks again for your advice. I ended up finding a local business (in Thailand, can you imagine!) which specializes in Mac repairs and upgrades. They did the whole 1TB upgrade for 6500baht (=$195) including labour. And did it the same day.
完成的
@johnnie99 You're welcome.
完成的
添加一条评论
添加你的答案
Dr John D Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 92
