跳转到主内容
Information and repair instructions for Frigidaire Freezer
Used Frigidaire model FFU21C3AW1 not going below 28 degrees
We bought this used upright freezer last year. It was 3 degrees when we bought it. We had it in an un-insulated garage and we had a heatwave of 120 degrees outside. We emptied it and brought it inside to try to take the stress off of the machine and replaced the seal as it was in poor shape. The highest we can get it is 28 and I can hear the compressor running constantly. My husband is an HVAC guy, so he knows a little, but is about to give up on the freezer and I want to dig a little deeper to find the problem, if possible. What would you suggest we start testing next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @kdalla5 ,
Have you checked that the condenser coils are clean and not dusty etc? Dirty condenser coils reduce the efficiency of the cooling cycle making the compressor work harder trying to achieve the set temperature as the heat that the refrigerant absorbed from the freezer compartment is not dissipated to the air as quickly.
You said that you replaced the door seal but check that it is providing a good seal with the door jamb in case it is a door alignment (hinge?) problem allowing the cold air to escape (or warmer air to enter if you prefer). Place a piece of paper between the door and the door jamb and with the door closed try pulling it out. It will come out with a bit of effort but it shouldn’t be too loose or just fall out by itself. Try this at various places around the door, top, bottom and both sides.
If the compressor is running constantly trying to cool down the freezer compartment but it is not reaching the set temp it sounds as though there is a problem with the sealed system somewhere.
Check for any frost on the lines to the evaporator unit from the condenser coils or to the compressor which may indicate that there is a blockage in the system.
Also check for any oily residues on or below the compressor or on the condenser coils which may indicate a lack of refrigerant in the sealed system. There is a special oil mixed in with the refrigerant to lubricate the compressor and sometimes when there is a leak, the refrigerant will escape to the air undetected but the oil may leave a trace.
The only thing after this is to get the high and low (suction) pressures in the sealed system tested to see if they are OK or not. The pressures will tell what and where the problem is e.g. lack of refrigerant, blockage, faulty compressor etc. Depending on your location you may need a licensed refrigerator repairer to do this due to the environmental regulations regarding the handling of refrigerant gases. Besides which they have the necessary equipment to do the checks. Here’s a link to the wiring diagram for your refrigerator. It is useful as it not only shows the wiring, it also shows the pressures for the sealed system
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kristin Dallas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 328
