跳转到主内容
加入维修社区 - 创建账户
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Ps3 update loop problem - 8002f0c1
Hope anyone can help me with this problem, have been trying everything but nothing seems to work. So I bought this beauty of a 60gb backwards compatible ps3 (CHECHC04) today with what I tought was a minor and easy to fix problem. When you boot the system up it needs to update but crashes at 4% of the update and gives the 8002f0c1 error, then it restarts and give the same error again. Can't really find much help about this error on the Internet.
Things I tried:
- Booting up in Safe Mode and trying to install an update through an USB with update file. (still gives the same error) Tried the latest update file, but also some older versions.
- I tried formatting the disk drive, but gives the error: "no acces to hard drive ps3". Don't know why??
- So I tought it must be a faulty hard drive, so swapped the hard drive for a known working ps3 60gb drive, but it gives me the same problems as above, also needs to update and the 8002f0c1 error.
So I can't really think of any other things to do? Could it be a hardware problem instead of a software problem? If so, is there a way to fix this? These systems are kinda rare so hope someone can help me fix this beauty... ? it would be really appreciated!!?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would try a different USB drive. Make sure that the drive is formatted as FAT32 and has the MBR partition table.
这个答案有帮助吗?
得分 0
1条评论:
Sadly didn’t work. Still the same problem.
Yesterday i opened up the playstation (the seal was still on there, so it was never opened up before).
I have repaired multiple playstation 3’s, but never seen one as clean as this one from the inside… looked like it has never been used, no dust at all. I tought maybe it would help if i replaced the cmos battery, sadly didn’t work aswell. Could it be that there is something wrong with the NAND chip?
完成的
添加一条评论
添加你的答案
Ritchie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 411
