Recently put in new switches, now scroll wheel and switches wont work.
Hello, I recently wanted to change the switches of my Logitech GPW superlight. I did this before on a G703, and it all went smoothly. Just now, I tried turning on the mouse and plugging it in. It did turn on, and the cursor was moving as I moved the mouse. But the switches and scroll wheel did not work. I checked my soldering and it is touching the plates, when desoldering the switches I didn’t see any plate come off. I kept the heat of my soldering iron at 350 C the entire time, which is the same temperature I used on the g703, and I replugged all the cables inside the mouse. Can I have some help?
Also, Ive seen people use 370 C for the same mouse, There is some brown crusty things at the edges of the solder, but my dad said that is just flux residue.
由 Vihaan Hazarika 完成的
Do you still have the old switches?
由 Andrew S 完成的
I think the problem has to do with the ribbon cable, it just doesn't go into the receptacle at the top PCB fully, I don't know why, it just doesn't.
