跳转到主内容
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
Rapid ticking noise instead of sound from speaker
Hello everyone !
I successfully replaced the screen of my OnePlus 5T, however a problem remains : the speaker does not play any sound anymore.
Instead a rapid ticking noise can be slightly heard when playing a sound (music, call, video…) but also when starting some apps (WordReference for instance, which does not require any sound). The noise will last a little more if I pause the sound supposed ti be played.
I searched for a solution and found out that the speaker is dead (some talked about humidity) and bought a new one : replacing the speaker did not solve the problem.
What do you think could be responsible for this ? Are there any solutions ?
Many thanks !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This a quote from someone who I found on Reddit that had the same problem and found the solution:
I found the problem myself and it's pretty dumb mistake - the cable over battery has to be flipped... In other words, the arrow on the cable should be facing top of the phone
这个答案有帮助吗?
得分 4
2条评论:
As silly as a mistake this was, it is the right solution. Proven on a OnePlus 8T as well.
完成的
The same silly mistake has been done by me. Fixed it on my OnePlus 7T.
完成的
添加一条评论
Bruh i tested this my self and it was working back
这个答案有帮助吗?
得分 0
添加一条评论
My mobile technician it may caused due to faulty sub strip or audio IC got burne or damaged.. replace first the main board to sub board flex or else audio IC of ur device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KasDing 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 2,605
