跳转到主内容
加入维修社区 - 创建账户
Repair information for Sharp televisions.
Television won't come out of demo mode
We have a Sharp LC32CHG69021K TV. For the past week whenever it is switched on, we have to go through a first time installation in order for it to work. On switch off it goes back to having Poland as its default. Then there is the model number emblazoned across the top left hand corner of the screen and a big K underneath in a blue box. This remains on the screen throughout. The only time this disappeared was when my 5 year old sat on the remote control. I have tried all the remote control buttons and they do not get rid of this notice on the screen, nor did sitting randomly on the remote control myself!
We were having another TV repaired and the repairer said that he thinks that the TV is in demo mode. If this is the case, how do I switch this off and get this to remain in normal set up?
Would really appreciate any help and advice please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @sjhitchen ,
Did you mean a Sharp LC32CHG6021K?
If so try a factory reset and check if this resolves the problem.
After the reset you will have to set it up again but hopefully only the one time.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your advice. Unfortunately neither the TV nor the remote have the requisite buttons to do the hard reset as explained in the article. Very baffling.
完成的
添加一条评论
Hey, I know I am kind of Late to answer this for you, But it is better late than never. So,I have gone through the same thing recently, where could not find out what was happening. and Later found out my Sharp TV was in store mode.
Googled for it and found at many places that it is a TV mode that needs to be turned off once you buy a new one. tried a factory reset didn't work,
finally turned off by turning off picture reset mode and demo mode under the system settings . Here are some methods to turn it off too, do give it a try nd turn off the store mode.
Hope that helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandra Hitchen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 30
总计 1,382
