跳转到主内容
Kernel_task causing immense slowdown when bottom case is on
I’ll try and make this short but this is a LONG journey with a ton of information. During a tune up (cleaning dust and installing new RAM and solid state) in my 2010 macbook pro, i forgot to unplug the battery before i began work. This ultimately fried the backlight fuse and an inductor and capacitor on the WLAN circuit.
After repairing both i power on my mac and it is INCREDIBLY SLOW-like unbearable, the fans are also at maximum speed. I check activity monitor and well
kernel_task is using litterally %600 of my cpu. Kernel_task is a process that takes away from other processes to reduce cpu temperature to prevent overheating , its part of macOS. My issue is the computer is litterally almost idle besides entrcheck.
i know my hard drive (technically actually a solid state) isn’t failing because its brand new. The Ram is also a known good component.
The twist: this all happens when the bottom case is on, if i remove the bottom cover and start the computer, it boots and runs like a dream. Im so confused and frustrated ive been at this for days now.
what ive done
reset SMC, PRAM, Swapped Ram and Hard Drive, spent hours on this doing research, please help, ive spent so long trying to get this thing up and running again. Id hate to just give up, but i dont know what else to do.
UPDATE 10/26/2021
after running the same diagnostics (TG PRO and Entrecheck) here are my results WITHOUT the back cover on
UPDATE UPDATE 10/26/2021
upon putting the back cover on, and taking it off and noticing the difference. I see the the palm rest temp sensor (located inside the trackpad flex cable) does not respond with the case on. This part has been ordered, will update after replacement.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Thanks to @danj for his support and assistance in this journey. I solved the problem. See the item marked in red.
upon investigation i noticed it was a little foam pad glued to the front camera ribbon cable . It would be pushed down when the case is closed, and pushing on it gently replicated the issue. This little foam pad prevents the metal case from touching the metal camera ribbon cable. For some reason the top of the case pushing this little pad caused my fan speed to go to 6000 rpms, and for kernel_task to take all of my cpu usage
yes….THAT… was the problem….
I removed the pad and the macbook works wonderfully. I suspect that foam pad prevents electrical connections. So i didn’t want to leave it like that. So I covered the connection with some thick electrical tape to achieve a similar effect. And will put a smaller pad on later…..then Voilà! My macbook is back! Thanks to everyone who spent their time helping me.
My solution is a unique case. Anyone else experienced this issue. I suggest SAFELY starting your computer up without nonessential components 1 at a time. Speakers, keyboard, trackpad. When i got to the camera. I noticed the problem stopped when the camera wasn’t connected, which lead me to the small pad.
Im not sure why it was causing all those issues. But i suspect maybe the pad was just too big and pressed down causing a short, I’ll probably never know…
这个答案有帮助吗?
得分 1
3条评论:
I’m experiencing a similar issue. Comp runs fine when the bottom case is removed. After putting it back on it will run fine for a few days. Then Kernel_task starts smashing the CPU again. Do you think my problem is related to yours? Could the case be pressing against something?
完成的
Hey Daniel, This was a few years ago so my memory may be a little foggy on the specifics. But if I remember right my issue started the exact moment I put the bottom case back on. I didn't even have to screw it in. The little foam pad in the photo was the only thing causing that issue. once I removed it i stopped having issues (i still use that MacBook on occassion to this day)
However, in my experience when you start having issues when you put the case on a device, there is either something touching something that shouldn't be, or the board is being flexed causing a short. Have you done any soldering work on this machine? If so check your solder work and make sure its solid and not bridging anything. Otherwise, I suggest safely starting your computer up without nonessential components 1 at a time. Speakers, keyboard, trackpad etc. Maybe that could start you on a path as well.
完成的
@mike2021 Hi Mike, thanks for your reply. Removing the bottom cover doesn’t “fix” the problem anymore, so now I really have no idea where to look. I never opened the bottom cover before this problem started and even though the Mac is from 2015, it looks like it’s brand new. I’ve used it rarely over the years. I’m afraid my only option now is taking it to an Apple service point which means I might as well buy a new one considering the age of my MB.
完成的
添加一条评论
Well your systems SMC services is in CPU Safe Mode which is when SMC’s sensors are not communicating to SMC because of a disconnection or failed sensor or the sensor is detecting a out of spec value (temp, current or voltage)
Do you have something disconnected? Battery, camera, display or drive?
If you do make sure they are connected.
You need to run deeper diagnostics! Depending on what the OS version is running on your system you might encounter a problem running the onboard diagnostics, as Apple messed it up with the newer firmware update within the newer macOS versions. But, let’s give it a try! Restart your system and press the D key to enter into the onboard diagnostics
Reference Mac startup key combinations
Hopefully you can get an error code to aim us to the area thats in trouble. If that fails you’ll need to find the original Grey CD that came with the system it will have an older version of diagnostics which should still work. Or, you’ll need the service diagnostics for your system its hard to find as Apple does a search and destroy on anyone posting it online.
So the last option and in some ways easier! Is to install the full version of this app TG Pro while it still not a complete diagnostics it might be enough to figure things out.
Let us know what the diagnostics tells you and/or post a snapshot of the TG Pro’s main screen with all of the sensors and fan showing 在已经存在的问题里加入图片
Update (10/22/2021)
Ouch! If the GPU logic is failing (the GPU sensor is not reporting in the TG Pro diagnostics) then your logic board will need replacing as the sensor is within the NVIDIA GeForce 320M chip. This is a unique GPU chip as its also the PCH logic for your system.
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
MacBook Pro 13" Unibody Mid 2010 Logic Board图片
指南
难度:
中等
1 - 3 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
7条评论:
Ive already tried onboard diagnostics which returned code 3403D which means the device is too old. Ill try the diagnostics software you suggested and will tag you when it’s finished. (Probably in like 5 hours because this mac is probably running at like 0.5 ghz) I also have some new thermal paste around, would replacing the thermal paste on an 11 year old laptop help at all? I did notice with the back cover off that the board was still quite hot to the touch (safely touched it of course)
Thank you so much for all your information i appreciate it.
完成的
@mike2021 - I would hold off on the refreshing of the thermal paste, instead let's get some data on your battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片 as often times I find this is the reason the system is overheating.
完成的
@danj
Battery has 231 cycles and is in good condition (this thing was barely used) hower TG Pro says my GPU temperature sensor is nonfunctional. I’d attach an image but i forgot and now its taking forever to boot again. Where would i get a gpu temperature sensor?
完成的
@danj further update, upon removing the back cover and running the same thing without the back cover on, the CPU is running notmally and now all sensors are functioning properly. I will add an edit with pictures
完成的
@mike2021 - Batteries also fail due to age so if this is not less than 4 years old it likely needs to be replaced.
As far as with vs without the bottom plate - That would imply you have a short somewhere did you put the correct screws in the given placement? Thats for both the logic board and the cover screws.
Lastly, did you replace your fuse and inductor that you burn't
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Michael Shepard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 421
