跳转到主内容
Repair documentation and information for the Google Pixel 4a 5G. Released on October 29th, 2020. Model number: G025E
33 个问题 查看全部
Possible to replace just the rear glass cover/lens over the camera?
I have a crack in just the glass cover/lens sitting on top of the camera of the Pixel 4a 5G. is it possible to just replace this part without disassembling the phone or getting a new phone casing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
CC, it can be independently replaced, but it’s a part of the back cover. In the 4a 5G, in order to access the back cover, you need to remove the screen, as seen in our guide here.
Once you have the rear cover removed, the flash, mic, and sensor need to be removed. You can see that assembly in this step. The lens cover is then adhered to the back cover.
If you source a replacement cover, you may want to find one with pre-applied adhesive, otherwise water resistance will almost certainly be lost.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
C C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 343
