跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
149 个问题 查看全部
Charging port with and whitout IC
Hi, i just realize that, you can buy charging port with and whitout IC or some chips. Is there any reason for it or just price. Is it there some benefits transfer old IC to new charging port? Thank you
There is link for exemple.
https://www.aliexpress.com/item/10050031...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unless you are very experienced in micro soldering, buy the port with the IC board. As far as I know, Apple devices won’t mind taking aftermarket charging ports.
Bottom line: you’ll save yourself quite a few headaches and a lot of money if you spend a little bit more and buy the charging port with the IC board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patrik Průcha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 683
