跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
How is the CPU fixed on the motherboard?
Hi guys,
I'll soon upgrade my old iMac 20' 2008 CPU from an Intel Core 2 Duo 2.66GHz E8335 to an Intel Core 2 Duo 3.06GHz E8435.
As I don't know what to do with the old CPU, I'd like to know if I could upgrade a macbook unibody 2008 13' 2.44GHz P8660 with it. My two questions are :
- Is the macbook CPU soldered or socketed as in the iMac ?
- Is the E8335 compatible ? Seems to be the same socket according to CPU-World but I don't know what the other specs mean ?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
As far as I know, the two CPU's are not cross-compatible. The CPU on the MacBook is soldered to the logic board and it is not recommended to try and replace it.
这个答案有帮助吗?
得分 2
2条评论:
Oh ok, what would you do personally with the old CPU then ? Sell it (and how much ?) or keep it just in case ?
完成的
You can try and sell the CPU on craiglist or eBay. I'm not sure how much they go for.
完成的
添加一条评论
The CPU on these machines is attached to the logicboard with a ball grid array (BGA). It's beyond the scope of a home workshop to desolder/solder them.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,152
