跳转到主内容
Google Pixel 2是谷歌第二代的旗舰手机,于2017年10月17日发布。这款手机的配备是5英寸AMOLED显示屏,64或128 GB的存储选项。它有三种颜色可选:黑色,白色,蓝色。
70 个问题 查看全部
SIM tray broke in half, only half comes out. SIM and other half stuck
I've tried getting it with things like sewing needles but it seems if anything I've only further lodged it into place.
Photos:
https://imgur.com/a/bNEtEV8
I will take this thing apart if need be, however I'm not sure which, if any, of the ifixit Pixel 2 guides are what I'd need to be able to access it, or without taking way more apart than necessary.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @printedwaffles ,
I would use the Google Pixel 2 Motherboard Replacement guide to gain access to the SIM card reader where hopefully you may be able to gently push the broken tray and SIM card back out from the reader, without causing too much damage to the reader pins. Perhaps by using a Spudger you might be able to do this
Getting the reader’s metal case cover off may be difficult if you want to try and remove it to lift the broken pieces out.
If you decide to try this, don’t skip the part about disconnecting the battery from the board. You don’t have to remove the battery, just disconnect it. There is always power on the board even though the phone may be switched off and you don’t want to cause any more problems than what you already have. The power button is not a power isolating button.
Spudger图片
产品
Spudger
$3.99
这个答案有帮助吗?
得分 2
添加一条评论
Or get some ifixit tweezers and carefully get the piece out
Tweezers图片
产品
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alberto Einsteino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 44
总计 1,177
