跳转到主内容
Can I fix a shaking image on my C434T Asus Chromebook?
My chromebook screen image began shaking. Everything else seems to be working. I tried powerwashing it as was suggested in my research but that didn’t work. Is there something else I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
What is power washing?
完成的
Hi @jayeff
Thanks so more marketing word change game.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @lunapuna,
Try connecting an external monitor (TV?) to one of the laptop's USB-C ports (USB-C to HDMI converter) and check if the display is steady or not.
If the external display is OK it may be a laptop LCD panel problem or a video cable problem.
Try gently moving the lid slowly back and forth to a position where it doesn't occur. If the shaking stops it may be a damaged video cable or just a loose connection, either on the motherboard or the display
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Elaine Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 229
