跳转到主内容
The Oculus Quest is the first standalone virtual reality headset that supports 6DOF tracking with cameras located on the headset itself. The Oculus Quest headset was released in May 2019 in 64 GB and 128 GB models.
53 个问题 查看全部
Only one eye works
Why does only one eye work and can it be repaired
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
this can be fixed really easily or it can be hard because it can be as simple as just reconnecting something or if something broke then that’s gonna be harder
这个答案有帮助吗?
得分 0
2条评论:
Ok but how do you fix it
完成的
open it and see if anything is disconnected and if some look disconnected try and reconnect it
完成的
添加一条评论
Disconnect the headset or the lenses? Please provide a link or manual to properly disassemble the headset to deal with lense issues. (If there is one out there). Thank you for the help!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Minnie's 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,789
