跳转到主内容
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
23 个问题 查看全部
问题已关闭
small spring found at rear of printer after clearing a paper jam .
where did a small stainless steel spring 40mm long come from that I found at the rear of the printer base when I opened up the back to clear a paper jam.
It has an eyelet on one end and sort of a hook on the other.
could it be a spring for the tension to the top door that gives access to the glass scanner pane ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
looks like to me you could be right or it is used for one end holding on to the printer and the other eyed end is put onto a gear somewhere a photo of the spring?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 79
