跳转到主内容
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Can the keyboard be replace?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The keyboard is very tricky to replace on its own. Its best to replace the entire uppercase assembly MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard Sadly, they are hard to come by as your system is still technically under warranty. Unless you had a spill or ripped off a bunch of keys Apple is on the hook to fix anything that is defective (not caused by you).
I would strongly recommend you find your way to an Apple Store or authorized reseller to get your system serviced if you can. Otherwise you’ll need to wait until parts become more available which could be awhile.
Replace an upper case and keyboard compatible with a late 2020 model A2337 MacBook Air 13 inch laptop. Includes the keyboard and palm rest area.图片
产品
$219.99
这个答案有帮助吗?
得分 2
1条评论:
Ok! thank you for the advise.
完成的
添加一条评论
添加你的答案
Shockinface360 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 520
