跳转到主内容
The Astro A40 TR Plus Mixamp M80, manufactured by Astro gaming, is a headset and amp bundle used to increase the stereo sound quality for the Xbox One .
How can I fixwhere the wire connects to the headset?
How can I fix where the wire connects to the headset? (Not where it connects to the mix amp). If I move it just right at the spot it connects to the headset it works, but generally it has stopped picking up sound from the mic.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To fix this problem, you will need a soldering iron and solder(included in this kit), a new TRRS headphone wire(like this one), a spudger or flathead screwdriver, and a Phillips #000 and JIS 1 screwdriver.
Follow this guide to fix the headphones. At step 5, plug in and turn on your soldering iron, then wait for it to heat up(you can test if it's hot enough by trying to melt the solder on the tip).
When the soldering iron is heated up, put the soldering iron on its stand, then hold a wire and solder onto the tip of the soldering iron. Wait until the solder is sucked up into the wire, then move onto the next wire, until all of the wires in the cable are done. Route the wire through the headphones to the speaker.
Remove the blue wire from the speaker by holding a soldering iron on the pad(silver part) and pulling on the blue wire with tweezers. Place the soldering iron back on the pad, then touch solder onto the pad and wait until a small “puddle" forms. Hold the soldering iron and wire on the pad for a few seconds, then remove the soldering iron, keeping the wire held there. Do this for the rest of the wires, one wire at a time.
Make sure the new cable is laying where the old one used to. Reassemble the headphones.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Danny Boi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 26
总计 1,294
