跳转到主内容
Cheap & Cheap Laptop CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.7GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
4 个问题 查看全部
Laptop USB Port only works at a certain angle
I’ve got a laptop with 2 USB Ports, but one only works at a certain angle. Works fine when pressure is constantly applied, no rotation. Works when tilted down (from upper view). Works when USB is between plugged in & unplugged. Sometimes my mouse lights up, but it doesn’t work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I have one that is intermittent also. I think it is the contacts inside the socket. They are a spring hump design. If you are careful, you may be able to lift them using a fine tweezer. They won’t need to come up much. Get the tweezer point just under the hump and lift it slightly. Do all 4.
这个答案有帮助吗?
得分 1
1条评论:
Be sure to first disconnect the charger and the battery!
完成的
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 545
