跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2397 个问题 查看全部
问题已关闭
iPhone 4 home button works poorly after a small water spill?
Hey all,
New to this site, can't believe a great site like this exists!
So here's my problem...
My girlfriend spilt water on her iPhone 4 (GSM) just so its clear.. about 4-5 months ago.
Ever since the water spill, the phone's home button does not work well.
What do I mean? - Well it does work, but only if you press on it quite hard, specifically the pressing has to target the center upper edge of the button. That is the only way it is functional at all. As you can imagine doing a "hard reset" is a HUGE pain in the butt, because you can never be sure if the home button is activated or not.
I was wondering if simply buying a new home button from this great looking site, along with any other necessary materials will be sufficient to fix this problem?
Well thats about it..
Looking forward to your answers,
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Replacing the home button should work for you.
My problem was similar. After almost a year of use, the iPhone 4 home button became less responsive. I had the phone sent for repair and moisture was detected inside the device. As the warranty was void, I decided to replace the button myself. It works like a charm now, responsive as on day one.
这个答案有帮助吗?
得分 0
添加一条评论
I got the same problem, where was the moisture found? On the home button, or on the sensor for the home button? Is this package enough? [关联产品丢失或禁用: IF182-017]
Thanks
这个答案有帮助吗?
得分 0
1条评论:
No idea. All I know is the moisture sensor was triggered. This package should be enough. In case it turns out not to be, you could try replacing the dock connector as well.
完成的
添加一条评论
not working at o cant turn on after water
这个答案有帮助吗?
得分 0
1条评论:
If the issue started after water damage you probably only need to disassemble the phone and clean the contact points between the homebutton flex and the connector on the dock connector and clean the back of the button and the frame contact point. This fixes 90% of them.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 7,394
