跳转到主内容
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
“A” and “D” on keyboard not working after replaced trackpad
I spilled some water on my trackpad few weeks ago. I bought new trackpad from ifixit and swapped the old one out. Before I “repaired” it, my keyboard worked perfectly. But after the “repair”, no response when I click “A” and “D” on my keyboard, althought the backlight is working…
Please help… Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have this same issue instead, my a and d stopped working after I changed my keyboard, my trackpad does has some moisture and I am unsure if replacing trackpad will fix issue
完成的
添加一条评论
3个答案
已选择的解决方案
Hi, I just had this very same issue with a new 2020 M1 MacBook Air. Model A2337 EMC 3598. The problem is not your keyboard its an incompatible trackpad.
Customer of mine brought in an M1 MacBook Air with a cracked trackpad. Everything was working great no issues with the keyboard. When I replaced the trackpad all of the sudden the A & D keys wouldn’t work anymore. Putting the old cracked trackpad back on would fix the issue. The new trackpad I had would work on another 2020 MacBook Air Intel version but that Intel trackpad would cause the same issue on the M1 as the brand new trackpad so I was confused. This particular problem with the A & D keys is caused by using a trackpad from an Intel MacBook Air on an M1 MacBook Air and possibly the other way around as well. I purchased my trackpads off of a vendor that lists them being compatible with all 2020 MacBook Air (Mobile Sentrix) but they are not.
I use a local parts distributor that has this trackpad in stock if you are still looking for it. You will have to order the trackpad from your exact model MacBook which I am assuming is the M1.
https://www.protechrestore.com/index.php...
这个答案有帮助吗?
得分 7
10条评论:
@wongngaisum - I only discovered this:
Be aware, when replacing the Touchpad (Trackpad) with a different nationality keyboard fitted, the keyboard will need to be re-mapped before it will function properly.
This is a process that is tied into Apple's Global Service Exchange (GSX), so cannot be done by anyone without access to this service (generally only ASP can do this).
Because of this, you need to get the trackpad from the same country encoded keyboarded the system has.
So the bottomline is without knowing the source of the Touchpad (Trackpad) you are taking a gamble it will work. At least it can be fixed but it will need to be serviced by someone who has access the Apple's re-mapping tool (an ASP).
完成的
Wow! Thanks for the info. I do not see too many non english macs come through but I will definitely keep this in mind.
完成的
Thanks @xnriqux and @danj ! My keyboard language is US English. Can I use the trackpad from https://www.protechrestore.com/index.php... ? Also, it means that iFixit is selling trackpads not usable on M1 macbook air. Is it possible to ask for a refund and notify iFixit of this issue? Thank you!
完成的
@wongngaisum I ordered that exact trackpad for my customers US English keyboard M1 and it worked perfectly without any modifications. As far as getting a refund through iFixit you would have to contact them about it.
完成的
@xnriqux @danj
I just replaced the trackpad from ifixit with the trackpad from protechrestore. Now my keyboard and trackpad both work perfectly! Thanks!
完成的
显示更多的5条评论
添加一条评论
Sounds like a bad keyboard the keys A & D share the same row line with S but they use different column lines! so Q & E should also be affected too, if not then the given keys are bad.
Contact iFixit for a new keyboard.
这个答案有帮助吗?
得分 2
4条评论:
Thank you. But only A & D are affected (they were working fine) and changing trackpad should not affect keyboard. I am not sure if the problem lies in the keyboard or the trackpad cable (i used a new cable) or what else.
完成的
@wongngaisum - As you had a spill these keys got hit, it just took longer for the problem to surface.
Replacing the MacBook Air 13" (A2179, A2337 2020) Trackpad Cable cable won't fix this as the raw keyboard signals are being sent to the logic board. Think of it this way you have a spreadsheet with rows and columns if you lost a row or a column others in that row or column would be affected too! If Q and E are working that points to the keyboard its self.
完成的
Thank you! but ifixit doesnt sell a2337 keyboard. Is there any place i can buy one?
MacBook Air 13" (A2337, Late 2020) Upper Case with Keyboard
完成的
@wongngaisum - Sadly thats it ;-{
Availability of the part is scarce!
Here's the P/N's for the Top Case & US Keyboard:
∙ Space Grey, Apple P/N 661-15386
∙ Silver, Apple P/N 661-15387
∙ Gold, Apple P/N 661-15388
完成的
添加一条评论
Hi there,
I have a similar problem.
Water got on the trackpad and the keyboard.
Some keys do not work or show other keys that have been pressed, although this is not the case.
When a new replacement keyboard is connected, all keys work normally again - except for A and D! The trackpad works without problems with the defective original keyboard and also with the replacement keyboard.
Now the question is, is this a keyboard problem or a trackpad problem or even a motherboard problem?
The macbook works flawlessly except for the keyboard. There are no problems whatsoever with an externally connected keyboard.
Please help.
这个答案有帮助吗?
得分 1
4条评论:
Xnriqu’s answer did solve my issue. @frischeis
完成的
But on my macbook the trackpad is the original one. Its not changed. I connect only a new keyboard…and i have the problem with A and D keys.
Strange!!?
Any ideas?
完成的
I have A2337 Air with waterdamaged touchpad, replace it with touchpad from A2179 Air and got a problem A and D keys dont work. Replacing with A2337 touchpad SOLVE problem!!!
完成的
My guess is you will need to replace keyboard with a keyboard of the exact same model. M1 trackpads aren't compatible with Intel MacBooks and vice versa, im assuming its the same with the keyboards and also caused the A & D key issue.
完成的
添加一条评论
添加你的答案
hellow0w 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 66
过去 30 天: 156
总计 3,858
