跳转到主内容
Repair and troubleshooting for the HP Pavilion dv4 line of laptops.
Data recovery black screen.
When i turn on my laptop it turns on but the screen stays black but the caps lock blinks on and off alot. I want to know how to get my data on the laptop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
What is the full model number of the laptop as shown on the information label on the bottom?
Easiest way is to remove the HDD and insert it into a caddy and then connect it to a desktop PC as a secondary drive.
There are links online that show how to connect a HDD from a dead laptop.
Is there a sequence to the Caps lock blinks? Check if there is a pause between the blinks e.g. 4 blinks - pause - 4 blinks - pause etc. This may be an error code which tells you what is wrong
Update (09/26/2021)
@ matt tav
Here's the maintenance and service guide for the laptop. Go to p.55 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
Here's a link that explains what to do when you have the HDD
这个答案有帮助吗?
得分 1
1条评论:
HP Pavilion dv4-2140us Entertainment Notebook PC
完成的
添加一条评论
添加你的答案
matt tav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 173
