跳转到主内容
加入维修社区 - 创建账户
Black Screen at startup
I just bought and installed a logic board in my Ibook G4 12" 1.33 GHz . The Ibook booted to the Apple logo with that spinning wheel and after a while it goes to a black screen with a frozen arrow in the center of the screen. The caps lock and number lock lights comes on when pressed but the track pad wont move the arrow in the center of this black screen . I need some help asap ,I am stuck. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I would double check all the logic board connections et pay special attention to the hard drive connector that must be pressed all the way down in its linear socket. Make sure that the bluethoot/airport card is well seated in the logic board. Don't clip the top case to the bottom case before completing internal verifications. Only connect the power button connector (blue & white wires) the its socket and try to power up the system.
这个答案有帮助吗?
得分 4
1条评论:
I tried everything mentioned and still got a blank screen. I tried command +"s'" and entered help but I don't understand the help codes that popped up . I am gonna need more help with this problem ,thanks.
完成的
添加一条评论
添加你的答案
Headley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 1,243
