跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
Why my ipad air wont turn on?
It was suddenly a dead battery so tried to charge it but after a few hours, there’s no charging logo and won’t open by pressing the top button. Left it overnight charging, still the same but it did heat a little, maybe it means it is charging. My charger don’t have any dust and can even charge my samsung type c phone. Also done the force reset but still wont open. Anyone who knew whats the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
i have the same problem too. i sent it to the nearest Apple service center in my place and they said that they need to replace the whole unit because the ipad has no screws thus making it impossible ‘‘for them’’ to open/repair but only if its covered by the warranty. im still waiting for the diagnostics results and i’ll update you asap.
这个答案有帮助吗?
得分 0
2条评论:
Update!
My ipad replacement was confirmed. They are going to change it. Dont worry cuz its covered by the warranty. Dont do DIY battery replacement! Just give it to apple service and let them do it. My ipad just finished its diagnosis and they didnt even tell me what the problem is, im pretty sure its a hardware probelm. And dont worry cuz u wont spend a penny while they replace it. Thats all.
完成的
I'm assuming your iPad Air 4 was still covered by the warranty. The question is, what to do after the warranty (and implied warranty) has already expired.
完成的
添加一条评论
Try replacing battery
you can do it DİY if you want İf you wanna pry on a LOT OF adhesive
if not logic board may be suspect
这个答案有帮助吗?
得分 0
2条评论:
Found a cracked ipad air 4 for sale
https://www.ebay.com/itm/185166679277?ep...
should do the trick just remove its battery
if it still wont work logic board(you may lose data)
if still broken,charging board is dead
完成的
@zygrei07 get off ifixit
İfixit is for right to repair/diy repair community
完成的
添加一条评论
添加你的答案
Desiri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 55
总计 1,118
