跳转到主内容
The Acer Aspire E5 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E5 series was introduced in 2015.
9 个问题 查看全部
Why won't my laptop turn on or charge after a RAM upgrade?
Hello,
I own a E5-571G-750T. Recently, I purchased 2 8GB DDR3 1600 MHz from Crucial, opened up my laptop and replaced the existing 4GB RAM with them.
My laptop was turning on fine until moments ago when I tried if I could play DotA2 on high settings. Suddenly, there was a small pop sound and my laptop died. I tried re-booting but to no avail. Even when plugged in, there’s no light indicating it’s charging.
Desperate, I opened it up, removed the RAM sticks, then put them back. I also tried tightening some components. Didn’t work.
Also tried a Youtube tutorial where I had to press the power button for a full minute, but it didn’t work either.
The only thing I haven’t tried is switching back to the 4GB RAM or interchanging the 8GB RAM in the slots. Is there even a point in trying? Or, could the problem be unrelated to the RAM upgrade?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would try removing one of the 8GB RAM sticks. If that doesn't work, you should switch back to the original RAM.
The manufacturer's BIOS or UEFI has a RAM limit-you can only use a certain amount of RAM with the computer. If you go over that limit, the computer will refuse to boot.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Uruviel Ereav 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 667
