跳转到主内容
The Acer Aspire E5 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E5 series was introduced in 2015.
Why won't my laptop turn on or charge after a RAM upgrade?
Hello,
I own a E5-571G-750T. Recently, I purchased 2 8GB DDR3 1600 MHz from Crucial, opened up my laptop and replaced the existing 4GB RAM with them.
My laptop was turning on fine until moments ago when I tried if I could play DotA2 on high settings. Suddenly, there was a small pop sound and my laptop died. I tried re-booting but to no avail. Even when plugged in, there’s no light indicating it’s charging.
Desperate, I opened it up, removed the RAM sticks, then put them back. I also tried tightening some components. Didn’t work.
Also tried a Youtube tutorial where I had to press the power button for a full minute, but it didn’t work either.
The only thing I haven’t tried is switching back to the 4GB RAM or interchanging the 8GB RAM in the slots. Is there even a point in trying? Or, could the problem be unrelated to the RAM upgrade?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would try removing one of the 8GB RAM sticks. If that doesn't work, you should switch back to the original RAM.
The manufacturer's BIOS or UEFI has a RAM limit-you can only use a certain amount of RAM with the computer. If you go over that limit, the computer will refuse to boot.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Uruviel Ereav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 847
