跳转到主内容
A lawn mower made by the American Company Toro
117 个问题 查看全部
Self Propelled Lawn Mower Not Moving Forward on Grass
I have a Briggs & Stratton High Wheel Variable Speed Gas Walk Behind Self Propelled Lawn Mower with Bagger ( model#21378) that was purchased 8 months ago. I was cutting the grass a couple weeks ago, and the mower stop moving forward half way through cutting. My neighbor has a passion fruit tree on their yard; the mower got stuck on a branch. I pulled it back a couple inches and move around the branch. That's when I realized the self propelled no longer working when engaged on the grass. I pushed the mower on the driveway and engaged the self propelled again, and it worked there. It stopped working on the grass but worked fine on concrete.
I did a little bit of troubleshooting. I removed the wheels to check for debris; they were cleaned. The driving belt was on the pulley. The belt did not look damage. When I engaged the self propelled, I noticed the belt tighten up a little. However, the cable felt a little loose. Do I need to replace the cable, or could it be something simpler?
The mower is still under the company's warranty, but the approved dealers told me they are 3 months behind and would not be able to get to it before that. I am hopping to find a solution online and not having to take it to the dealer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There is an adjustment for the drive cable described in the owner’s manual. You may need to take up a little on it. If you don’t have the manual, it is available online by searching “Toro model #21378 owner manual”.
这个答案有帮助吗?
得分 1
1条评论:
@mike3 that was it. I adjusted the cable, and it's been working. Thank you.
完成的
添加一条评论
添加你的答案
Ferice 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 46
总计 337
