跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Replaced battery bent when removing, can I still use it?
I followed the tutorial to replace my iPhone SE (1sg gen) battery, and like for many others, only one of the strips of old adhesive came off clean, so I had to pry it out so I could weaken the rest of the adhesive with isopropyl alcohol and carefully get it out with a spudger.
It bent a little bit in the process but I managed to make it flat again and it does not look damaged. Is it a bad idea to reuse it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It’s definitely not as safe as the original one, but your mileage may vary. Most people kept using it without major issues.
这个答案有帮助吗?
得分 2
添加一条评论
Punch it flat put it in that’s what I would do its safe unless its torn open and you can see silver inside
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Ristic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 120
