跳转到主内容
型号A1989,EMC 3358.更新了现有设计、处理器选项并且更换新的键盘材质.有银色和深空灰色可供选择.于2019年5月发布.
134 个问题 查看全部
MacBook Pro Screen looks weird when I opened it more than 45 degrees
So, it’s been two days since this happened, everytime I open my Macbook Pro 2019 in more than 45 degrees, the screen start flickering and the white color seems weird, like yellowish and saturated. Other colors seems okay. I already tried from calibrate the display, and other troubleshooting ways, but no change. I think it has something to do with the cable, probably like the flexgate issue? Because if i open the screen less than 45 degree, the display looks just fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The flex cables which bring the displays signals to the display from the T-CON board have become damaged!
Do you still have warranty cover? I how about AppleCare+ service contract?
Sadly, you’ll need a new display assembly to replace yours to fix this MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide to put it in 2019年带Touch Bar的13寸MacBook Pro 屏幕更换
MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly图片
产品
$479.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
赤い薔薇inswaar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 161
